SLP4camaroSS
Old Sep 26, 2006 | 12:57 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Default SLP4camaroSS
Clear out your PM's please.
Reply,
The teeth count for both systems are different, the 3 chanel uses a 106 tooth ring gear and the 4 chanel system uses 2 59 tooth rings. You would have to make up a ring with enough teeth on it so you could fool the system. I am trying to come up with a gear on the pinion yoke but I have to put a lot of time into R & D so over the winter I'm gonna try somethings out.
Old Sep 27, 2006 | 12:07 AM
SLP4CamaroSS's Avatar
so the whole system even if u changed out the abs mod and everything it wouldnt work alright ok gotyea
