bent axle
Old Sep 26, 2006 | 07:09 PM
crazymofo1986's Avatar
Default bent axle
well my axle is bent on the pass side. i have 130,000 miles what all should i get while im in the diff and pulling the axle.what seal and others is what im asking. also where can i get everything.
Old Sep 26, 2006 | 08:41 PM
no one
Old Sep 26, 2006 | 09:49 PM
what axle am i sopposed to be geting?
10 Bolt GM 8.5 Rear Axle 28 Spline 33 3/8" 5 on 5 Lug
10 Bolt GM 8.5 Rear Axle 28 Spline 31 7/16" 5 x 5 bolt
10 Bolt GM 8.5 Rear Axle 28 Spline 32" 5 on 5 bolt
10 Bolt GM 8.5 Rear Axle 28 Spline 31 3/8" 5 on 5 bolt
10 Bolt GM 8.5 Axle 28 Spline 29 5/8" 5 x 4 3/4 Lug
10 Bolt GM 8.5 Rear Axle 28 Spline 30 7/16" 5 on 4 3/4
10 Bolt GM 7.5 Rear Axle 28 Spline 28 1/2" 5 on 4 3/4
Old Sep 26, 2006 | 10:06 PM
Studytime's Avatar
Get one out of a stock car. Just get a take-out axle.
You need a 7.5" 28-spline axle. If you have traction control you need an axle out of a car that had 4-channel ABS. If you don't have traction control you could use either axle.
You should probably change the outer wheel bearing and the wheel seal if you had a bent axle. You can get those parts at AutoZone. Just tell them your application.
Anything else?
Ben T.
Old Sep 26, 2006 | 10:46 PM
what do u mean by take out axle? but thanks for the help thats everything i need. and autozone doesnt have the axle tho jus the other stuff right?
Old Sep 27, 2006 | 07:14 AM
Studytime's Avatar
Right. I meant an axle out of a wrecked car. Do you have traction control?
You're right. AZ will not have the axle.
Ben T.
Old Sep 27, 2006 | 06:07 PM
no t/c
