what will tp4400 do on n20
Old Jul 2, 2002 | 10:16 PM
fastlif's Avatar
Default what will tp4400 do on n20
given that I haven't made a good pass yet I am still thinking...not gonna change yet.
I have vig#7 on MTI heads/cam car that so far has run high 11's @113 best usually 112 in this Mississippi heat.
All the really fast head/cam cars run more convertor like the tp4400. but what would it do on 100 hp n2o? I would love to run low 11's "really low" on motor (i'm not going to lighten enough for 10's)but I want the n2o on top of that.
I just put 3.73 in and have not run yet.
so what ya think?
Old Jul 2, 2002 | 10:30 PM
Loco's Avatar
Default Re: what will tp4400 do on n20
With just boltons, I ran 12.0-12.1 @ 111-112. When I sprayed a 100 shot (TNT), I ran anywhere from 11.7-11.8 @ 114-116 with my Yank 4500. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
<small>[ July 04, 2002, 09:43 PM: Message edited by: Loco ]</small>
Old Jul 2, 2002 | 10:59 PM
RyanJ's Avatar
SSU Moderator
if you are gonna spray id put in 3.42's and keep the #7. concentrate more on little mods and tuning. good exhaust, some mild weight reduction, and a nice track only set of tires. maybe a make-shift track only intake setup. with MTI and the #7, you should EASILY see 11.5 with a well set up tune and all the little stuff worked out. on the hose you'd stall REAL high, but the shift extension is long enough the thing will spray just fine. FYI, with an LS1 intake, full weight, h/c, 3.42's/3600...Brooke ran 11.2-3 NA and like 10.4 or so on the juice.
Old Jul 3, 2002 | 08:15 AM
Ragtop 99's Avatar
The YTP 4400 is not ideal for nitrous; a 100 shot is pretty much the limit. I'd get traction and make sure you can spray it out of the hole. It helps if you are able to spin the motor to 6800.
Old Jul 3, 2002 | 10:08 PM
The Guy in MY 99TA's Avatar
I'm glad you asked that Shawn..... I was wondering the same thing. I want a TP4200 though I think.
Those numbers weren't very impressive on N20 there Loco.
Josh S.
Old Jul 4, 2002 | 10:02 AM
SPANKY LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Guy in MY 99TA:
<strong>Those numbers weren't very impressive on N20 there Loco.
Josh S.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think that was kind of the point, it is not really a nitrous friendly converter. I would think that if you tried to launch on NOS, the converter would probably flash to 5800+, only leaving you 600-800 rpm of powerband, nitrous generally likes a wider powerband and lower shiftpoints. I had a TP4400, and if I was ever to spray, I would have gone with a TPE3600, IMO the best of both worlds. Good luck, Shawn
Old Jul 9, 2002 | 05:05 AM
98TAauto's Avatar
personally i would focus on your NA runs.. with just the vig3600 and small bolt ons(stock internals) im running upper 11's on nittos <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
with heads/cam and that stall you should easily be 11.3-4 for sure!
spraying should get you 10's off the line.. just my 2 cents <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
