Tru-trac experiences
Old Oct 2, 2006 | 07:29 PM
TRex's Avatar
Default Tru-trac experiences
Well, I've had the tru-trac in my 8.8 now for about 6 months and it seems very different in several ways to my stock rearend, wondering if anyone else notices similar things. For example:
1. Seems to be much noisier in a positive gear noise kind of way. I'm not talking about the typical gear whine that you get with a ring and pinion set improperly, this is more a low speed noise like a second manual transmission in the back of the car. Anyone else have this ? Could it also be related to swapping to a adjustable BMR torque arm with poly bushing and just transmitting more noise ? Not overly objectionable, but definitely sounds like a machine
2. Seems clunkier, like on shifts, coast to drive, and going from reverse to forward. I know it's not the lash, becasue there is only .008" of lash. The tru-trac guys said this was normal, but I wonder why the 10 bolt wasn't like this with the Torsen ? Of course, could just be that the torque multiplication is so much greater with the 4.30's that it jerks harder now.
3. Traction is much better out of corners, it actually bites now. Only thing is, with the 4.30's, it's easier to overwhelm the tires
If you have a tru-trac, post of your experiences !
Old Oct 2, 2006 | 08:23 PM
97M6Formula's Avatar
I love my True Trac especially comoning out of a turn its so more responsive at sticking it to the ground or at least trying to before they break loose. It's nice to feel it instantly lock. It just feels real solid back there and doesn't have the drivability issues that a spool or even locker have when you want to cruise on anything but a slick. I'm real happy with it.
Old Oct 3, 2006 | 12:40 AM
CW00BlackTA's Avatar
After running a Detroit locker, I'm happy as hell with mine. Works great. Mine doesn't make any noise.
Old Oct 3, 2006 | 08:37 PM
Dragula's Avatar
1 and 2 sound like Torque arm issues.
