How to fit BMR relocation brackets on 9"
Old Oct 8, 2006 | 11:19 AM
WS6FirebirdTA00's Avatar
Default How to fit BMR relocation brackets on 9"
I keep seeing that people make the bolt in ones work, but what are you doing? I assume you cut the tab off for the shock and then weld them, is this correct?
Old Oct 8, 2006 | 12:14 PM
2001z's Avatar
There are certain ones you can buy for a 9in that should bolt right up. If you have some that came off a 10bolt it most likely will not bolt right up.
Old Oct 8, 2006 | 12:58 PM
thats what I was wondering though, the weld on ones are the same as bolt ons, excpet the bolt ons have the tab for the shock correct? I just dont want to spend more money on LCA brackets if I can make these work out, it seems some people get them to work.
Old Oct 8, 2006 | 01:34 PM
2001z's Avatar
Ya some people just went ahead and welded them on . I just sold my relocation brackets that wouldnt fit on my 9in enless i where to weld it . Some one chime in to help him out with this
Old Oct 8, 2006 | 01:45 PM
thanks
Old Oct 8, 2006 | 02:31 PM
CW00BlackTA's Avatar
It's pretty easy to modify the bolt-ons for a stock rear to fit a 9 inch. Just cut and reweld the tabs. If you try to fit them up, you'll see how to do it.
Old Oct 8, 2006 | 03:03 PM
ok thanks, just the tabs for the shock bracket right?
