pics of housing?
thanks
The housing up front is just like the 12 bolt, with the difference being that the torque arm bolt holes don't go all the way through...you use 4 shorter bolts instead of the two long bolts with nuts on the ends.
if you drilled the holes all the way through your probably compromising the integrity of the housing, if not drilling through the interior walls
. i would call moser, most of those guys are pretty helpful. if the first guy doesnt know the answer ask to talk to someone else..thats what i did to find the torque specs for the backing plate nuts and bolts
if you dont mind me asking...why do you want through bolts?
That was the only thing that drove me to a Strange 12-bolt.
Moser claims there design is like that for the strength of the housing. It is common for the bolts to come loose and when they do its a mess. The problem is once they are loose if you do a hard launch you are going to break something. I don't care what brand torque arm you have or how good it is.. you do a hard launch with finger tight bolts you are going to break it.
