9 Inch drain plug?
Old Oct 16, 2006 | 09:49 PM
getusum's Avatar
Default 9 Inch drain plug?
I just ordered my moser 9 inch.....Being shipped oput today, ordered on Friday...just saw on another dealers web site, that you have to specify the drain plug?..WTF...Pleaswe tell me I miss read or it's a misprint....I know fro $2500.00 it comes with a drain plug.....I'll be sending it back if it doesn't...also, if it doesn't why wouldn't the dealer tell you or reccomend it?
Old Oct 16, 2006 | 10:53 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Just draining the oil doesn't mean you will remove all of the moisture and what ever else has built up over time. You really should drop out the center section and clean it out and inspect it every once in a while. You made the choice to invest into a hi-performance part so take care of it and it will take care of you. I have witnessed in my own car that after a few seasons of abuse that cleaning it out and brake cleaning it really helps in driveability and durability.
Old Oct 16, 2006 | 11:27 PM
Dragman's Avatar
Originally Posted by Scott@DrivelineSolutions
Just draining the oil doesn't mean you will remove all of the moisture and what ever else has built up over time. You really should drop out the center section and clean it out and inspect it every once in a while. You made the choice to invest into a hi-performance part so take care of it and it will take care of you. I have witnessed in my own car that after a few seasons of abuse that cleaning it out and brake claening it really helps in driveability and durability.
I agree!!!
Old Oct 17, 2006 | 05:00 AM
EPP's Avatar
EPP
Same here. Bob
Old Oct 17, 2006 | 10:25 AM
Avengeance's Avatar
Youre gonna send a $2500 rear end back, spend a couple hundred on shipping back, because you forgot to order a drain plug?
I ordered mine from DLS and it skipped my mind when I placed the order... I knew it had to be specified but I totally forgot. Luckily I called in time to have one installed before it was assembled. THANKS SCOTT!
Just have one installed before you install the rear in your car.
Old Oct 17, 2006 | 12:46 PM
LS1Tech Sponsor
Luckly I just got some weld in ones in and they are very easy to install.
