moser 12 bolt wows!!!!
With the horsepower you are pushing, I would switch over to a 9 inch with a spool. No problems on the street with a spool, other than the chirping on tight corners. Bob
I am a little concerned because I have a new Moser 12 bolt and have only heard about gear set up issues from Moser in the past. Do the gear set up issues still exist?
Ive been very curious on the complaints on gear noise that people have had over the years on Moser 12 bolts, In addition to N2O-ARMD issues above. On the noise issue, I know Mosers response is that the gears are for severe duty/ racing application. Having seen 2 of them with a few miles on them, it appeared that they were possibly set up to tight. Moser gears were replaced with Richmond and Kodiac street gears and called it good, (No noise, usual oval contact pattern). I assumed (my bad) that it is was a set up issue. I pulled the cover on my TT project car last night to find a very good contact patern (both drive and coast) and 0.007" backlash. The contact pattern was much more generous than a a typical set of street gears and I imagine this must contribute to the noise.
My cars are more race than street so I always run with a spool. Maybe the spool will help somewhat, but unless the Eaton case was deflecting I couldn't see it as the total source of the problem. Mine will be on the track soon, I'll tell you if I end up having the same problem. It probably won't 60 ft like it did in the Vet but it should give the moser a good work out.
Also....make sure that there is nothing going on with your pinion angle. I know you said that you checked it...but double checking never hurt. Is that all that is happening (chewing up gears)?
Who is installing and setting the gears?
