Dana S60 Install Help
Old Oct 29, 2006 | 07:49 PM
Taphee6's Avatar
Default Dana S60 Install Help
I am preping the S 60 for install and I noticed the yoke for the drive shaft does not have the C stlye clips to hold the drive shaft to the rearend. Also the yoke is not tapped. So I am assuming you do not use the stock ones or What am I missing or need to do?
Also what size u bolts are needed for the sway bar?
Outside of that I think I have everything else. The brake lines are on, the sensor for ABS is installed.
Thanks in advance...
Old Oct 29, 2006 | 08:15 PM
RPOWU8's Avatar
You need u bolts for the yoke, Precision Universal Joint P/N 330-10. The S60 doesn't use the ubolts for the sway bar, there are brackets welded to the axle tubes where the sway bar mounts to. Just get some 10 mm bolts to bolt the bushings to the axle. Take the original sway bar u-bolt nuts and get (4) 10mm x 25mm long bolts with matching threads.
DJ
Old Oct 29, 2006 | 08:28 PM
Taphee6's Avatar
Default Thank you
Thanks for the info. I appreciate it....
Old Nov 20, 2006 | 01:53 PM
Ziptie's Avatar
Mine came with the sway bar bolts, and bushings.
