rear end fluid?
Old Nov 5, 2006 | 12:06 PM
who281's Avatar
Default rear end fluid?
what fluids should i put into my rear end...
can i get them at autozone?
and how the hell do i change the fluids...
sorry i have never changed the rear end fluids only tranny and oil? lol
Old Nov 5, 2006 | 01:31 PM
chicane's Avatar
1. Do a search on this subject... it has been answered many, many times.
2. You could get something from Autozone, but 99% of what they have is crap.
3. Pull the rear cover off and drain. That way you can get a look at the condition of what is still alive in the differential and what may need to be serviced. Clean surfaces of the housing and cover... re-seal, add lube and friction modifier.
Old Nov 5, 2006 | 01:33 PM
who281's Avatar
ok thanks...and sorry i tried to search but it seems to not be working again?? or maybe thats just my computer?
Old Nov 5, 2006 | 04:14 PM
Gregg1LE's Avatar
There are problems with the search funstion.Do a search on Google and you'll get your answers.
Old Nov 6, 2006 | 04:19 AM
chicane's Avatar
Oops.. didnt realize search wasnt working.... my bad.
Old Nov 6, 2006 | 06:45 AM
koolaid_kid's Avatar
Buy a gasket, 2 qts. of 85w-90, and gasket sealer (I use UltraCopper).
Remove the cover and drain the fluid. Clean the surfaces, apply gasket sealer, and install the gasket/cover. Fill from the passenger's side (plug uses a 3/8" ratchet).
I bought a pump at Auto Advance that fits in the fluid bottle and lets me pump straight into the diff.
Hope this helps.
Old Nov 6, 2006 | 12:29 PM
nofearracing28's Avatar
do you need to get use other additives?
