12 bolt moser
Old Nov 6, 2006 | 07:55 AM
Disturbed Bird's Avatar
Default 12 bolt moser
just wondering if i can blug that vent on the left axle. i have a hose coming off of it i guess its a vent but every time it i run it hard when i park it it leaks out a little bit of fluid. should i plug it and if so with what
Old Nov 6, 2006 | 07:08 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
If you plug the vent hole you will blow out the seals. The air inside will expand when your rear axle warms up so I would just zip tie it up to something that way the oil will run back down the hose.
Old Nov 7, 2006 | 12:25 AM
alright thanks
Old Nov 7, 2006 | 05:28 AM
EPP's Avatar
EPP
Install a longer two foot section of hose on it, and nylon tie it up as has been suggested. Bob
Old Nov 7, 2006 | 07:43 PM
Reverend Chaos's Avatar
I actually made an "oil catch can" out of an empty brake fluid bottle. drilled a hole in the cap the same size as the hose, ran the hose into the bottle and made a smaller hole torwards the top of the bottle to vent any kind of pressure and zip-tied the bottle out of the way. Every time I change the oil I just unscrew the bottle and empty it (usually not that much) I got sick of cleaning the mess after a few thousand miles. it's worked great and cost nothing
