alternative to 12-bolt
Yes, I've checked my pattern and it looks the same as when I set it up. If the pattern moves, it's because the shims weren't fully compressed or the housing is flex'ing.
Mike
mikronite is a process that you put gears through similar to sand blasting, the gears are still made of steel
http://www.vincihighperformance.com/...IN%20PAGE.HTML
for those looking for some light reading, look at the car craft jan 2007 issue page 44.
i'll see what i can do about getting some 1.4 60ft times just for you next month. i doubt i will, might finally see some 1.5s though.
ok prostock cars do not make 6,000 plus hp, they make around 1200 on motor rougly but the fuel cars make the 6,000 plus hp and even then its theoretical because they cant prove it because no dyno can handle it
Car Craft
05 mustang
3.55 gears
ford 8.8 rear
made 6 rwhp more
MM&FF
05 mustang
ford 8.8 rear
made 7-8 rwhp more
oh yeah almost forgot, V. Gaines is from colorado, about 10 mins from where i live
