set me straight on this
Old Nov 9, 2006 | 09:23 PM
FRUSTRATED T/A's Avatar
Default set me straight on this
alright i have a 2000 trans am auto. IM pretty postive the car has 2.73's in it. And it has the Torsen differential. So do i have a 2 series carreir or 3 series. At first i thought all torsens were 3 series and all auburn were 2 series. Now after reading i realize that all differentials can be 2 series or 3 series and it depends on the factory gear ratio right? 3.23 and up=3 series and 3.08 and down = 2 series. Am i correct? Thinking of puting in 4.10's
My car is only a weekend worrior so i was thinking about puting a mini spool in off of summit the only place i could find them. Now i have no clue if they will fit in my torsen diff or just an auburn. Do they remove the spider gears and other gears in an torsen or do the gears stay their or do they only work with auburn. An auburn can be put in my housing correct?
Please help im so lost.
Old Nov 9, 2006 | 11:57 PM
GOaT Cheese's Avatar
The carrier series is the same as the first number in the ratio. For example if the original gear was a 3.08, then it is a 3 series, if the original gear was a 2.73, then it is a 2 series, if the original gear was a 4.11, then it is a 4 series, etc. etc..
Old Nov 10, 2006 | 04:43 AM
alright got it then i have a 2 series thanks! When looking at gears i have to make shure their 2 series compatble right?
Old Nov 10, 2006 | 08:50 AM
Correct.
Old Nov 10, 2006 | 11:06 PM
buttermantoast's Avatar
Anything under a 3.23's is a second series carrier anything 3.23s and up is a 3rd series!
Old Nov 10, 2006 | 11:09 PM
A factory 3.08:1 is a 3 series.
Old Nov 10, 2006 | 11:17 PM
any one know about the mini spools and how they work in our rear ends, and what rears diff do they work in.
