Changing gears ...Help
Old Nov 10, 2006 | 01:25 PM
jp74's Avatar
Default Changing gears ...Help
Hello,
I am looking to upgrade from 2:73's to 3:23. There is a stock ring and pinion with carrier from a 2001 Camaro ss (7.5 Rear end) for sale. Will this fit my 1998 formula? What else would I need? Thanks in advance?
Old Nov 11, 2006 | 04:31 AM
FRUSTRATED T/A's Avatar
i believe you have an auburn in your 98 and the other diff would be a torsen, which some say break quicker. I would stay with your diff and get some gears and have them set up right. You would need a 2 series gear or a ring spacer if you had a 3 series gear to put in. if you did it your self you would need a master rebuild kit. Also you might need to rent some tools to pull bearings which should be replaced while your in their
