12 bolt and driveshaft ?? help needed
Old Nov 15, 2006 | 06:46 PM
2000NavyZ's Avatar
Default 12 bolt and driveshaft ?? help needed
i recently blew up my 10 bolt (imagine that) I'm going the right way and buying a moser 12 bolt. Do i need to do anything to the driveshaft to make the rear end fit? Ie, shorten? buy a new one??
TIA
.....Also is it worth going with 33 spline axles and a 1350 yoke for $2400 vs. the basic package for like 2025$$$
My car will most likely never make over 450 whp and is never going to be a weekend racer, maybe just a few times a year. But would love to launch it on slicks!
Old Nov 15, 2006 | 08:21 PM
NOZR1's Avatar
When I replaced my 10 bolt with my Moser, the stock driveshaft fit fine with no problems. I also went with the 33 spline axles and 1350 u-joint. I would say do it if you are putting a sticky tire on.
Old Nov 16, 2006 | 04:09 AM
EPP's Avatar
EPP
Moser 12 Bolt with Truetrac for F Body, your choice of gear ratio
33 Spline Axles with 10 year warranty
ABS (3 channel) or ABS/TCS (4 channel)
Performance aluminum cover
$2,350.00 plus Freight Collect Shipping
Moser 9 Inch with Truetrac for F Body, your choice of gear ratio
31 Spline Axles
$2,400.00 Shipped by UPS
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Shipped by UPS
Moser 9 Inch with spool, your choice of gear ratio
35 spline axles
Aluminum center section
$2,250 shipped by UPS
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,000.00 shipped by UPS
The factory driveshaft will indeed bolt back in either the Moser 12 bolt or nine inch.
If using the factory driveshaft, a Napa pn# 240-0447 conversion u joint will be required.
Call us at 260 244-4808. Rear ends are ready to ship two days after order is received. Thanks! Bob
