moser axles
Stock axles are weak.. they suck. i broke the driver side axle at the drag strip on a 255 bfg drag radial leaving from 3 grand... i also broke the auburn posi at the same time...
here is my theory...
either the axles suck and can't handle the twist and force put on them by trying to move a 3500 lb car and driver quickly or...when the spider gears in the aubrurn let go they got lodged "somehwere" which caused something to lock up which then caused the axle to break..LOL <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
after i broke the stock axle i went with the mosers and have like 45 track passes on them with et streets leaving from the limiter or close to it and HOOKING .. they didn't break..
MY supposedly bullet proof eaton diff took a dump before the axles did.. so did my high torque torsen...
bottom line is if you are gonna be draggin your car and you have a 6 speed be preppared to break your rear end.. unless you go to something bigger .. either the 12 bolt or a 9"..
99 Trans AM (last year setup)
4.10s
Hooker L/Ts w or y-pipe
Mti lid
Hotcam
flow master exh
12.34@111.8 w 1.72 60ft
