type of carrier
Old Dec 6, 2006 | 03:00 PM
johnLs1camaro's Avatar
Default type of carrier
can anyone tell me what carrier on my 98 z8 7.5 10 bolt is thanks
Old Dec 6, 2006 | 03:12 PM
alamantia's Avatar
3.08 and numericaly lower should be a 2 series and 3.23 and numericaly higher should be a 3 series. I thought Torsens were in every F-body between 98 and 02 but I have heard of some people on hear having eatons in 98, jack up the rear of the car and spin one wheel, if the other turns teh same direction its an eaton, if the other spins the opposite direction its a torsen
Old Dec 6, 2006 | 03:55 PM
Ouija's Avatar
If you have a manual then you have 3.42 gears. (GU6)
If you have an auto look at your door sticker to determine your gears.
If you have the RPO code GU2 it's a 2.73 gear with a Series 2 carrier.
If you have the RPO code GU5 it's a 3.23 with a Series 3 carrier.
Old Dec 6, 2006 | 04:06 PM
2001NBMZ28's Avatar
I'm thinking the '98's had the Auburn.
Old Dec 6, 2006 | 08:09 PM
thanks ill check
