6 speed problem
Old Aug 2, 2002 | 09:20 PM
john butler's Avatar
Default 6 speed problem
i have a 98 z-28 w/ an MM-9 6 speed. my girl friend and i made some passes w/it last night at the track, and today the car goes out and comes in to gears slow, hard to get in to reverse, won`t down shift from 6th to 5th, and the clutch seems to be low on the pedel. it`s all stock but i just put a new flywheel and centerforce dual-friction, and energy suspension mounts in it. has anyone had this problem? if so i new advice, any ideas?
Old Aug 2, 2002 | 09:47 PM
RTCamaroSS's Avatar
Default Re: 6 speed problem
Did you change the slave and master when you did the clutch install? If not, you need the updated parts. GM released new parts in 2001 i beleive.. they are much better than the 98 and 99 stuff.
Old Aug 2, 2002 | 10:14 PM
i forgot to mention that it has a vibration at 2500, in all the gears now.
