Question on wheel bearing replacement
Old Dec 15, 2006 | 05:33 PM
Chevy053's Avatar
Default Question on wheel bearing replacement
Is there anything inside the axle that the bearings back up against when pushed all the way in? The cut-away diagrams in the GM manual dont show anything of that sort and say just to push them in untill their tool bottems out on the outside of the axle housing.
Esentaly do I have to be careful and not go crazy to make sure I dont push them too far in?
Old Dec 15, 2006 | 06:48 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
What is the year, make, and model of the vehicle you are working on?
Old Dec 16, 2006 | 01:51 AM
Chevy053's Avatar
This would be for a 1994 Camaro M6
Old Dec 18, 2006 | 06:54 AM
NOBR8KSS's Avatar
Yes....the inside diameter of the axle tube steps down and it acts as a stop for the wheel bearing. It actually steps twice...the largest diameter holds the seal, the next smallest holds the bearing, and the smallest diameter (thickest material) acts as a stop for the bearing.
You'll be able to see after you pull the bearing.
Old Dec 18, 2006 | 09:26 AM
Chevy053's Avatar
Thanks....I figured there kinda had to be something of that sort. But like I said the GM manual diagrams dont show it.
Thanks again.
