boost+traction=
Old Dec 16, 2006 | 07:15 PM
Deckhand's Avatar
Default boost+traction=
About couple years ago, I had an eaton limited slip differential installed with motive 4.10 gears. Keep in mind this is a 8.5" 10 bolt, not the 7.5" that most fbody ppl break. I also used ARP bolts for the main caps on the differential along with the T/A Performance rear end girdle. Everything worked good for a long time. Fast forward to now, I have a different motor with a blower setup (making ALOT more power than before). Last night tuning on it, I decided to do a full out launch.. it hooked hard, and moved out quick. Tried it again, and KABLOOM!!
Im debating whether to get another set of gears and risk it happening again, or just go with a ford 9".
Old Dec 16, 2006 | 10:23 PM
mzoomora's Avatar
14 Second Truck Club
An 8.5 is a good rear, but with that much power + traction + the weight of a truck = not strog enough. Truck looks nice though.
