10 bolt A4 guys
Old Dec 19, 2006 | 09:56 PM
JUICED96Z
Guest
Posts: n/a
Default 10 bolt A4 guys
For those on 10 bolts and auto trans, no trans brakes.
Have you broken your 10 bolt with suspension pre-loaded and on stickies? (foot on brake, spin the motor up some, car raises in the back some, foot off brake to launch.
If its still alive does your rear have a T/A cover and studed?
Old Dec 19, 2006 | 10:05 PM
TWS's Avatar
TWS
No. I raced my '94 Z28 for years with the stock 10-bolt, GMPP 3.73 gears, and a T/A girdle.
For the majority of that time, it was a mid-12 sec car. Not like I was running super impressive ET's or putting a lot of power to it. However, I raced very regularly and always preloaded after staging. Anywhere from just bringing the converter up "tight" to the limit that the brakes would hold.
Old Dec 19, 2006 | 11:42 PM
02 BLK WS6's Avatar
I broke mine not preloading. It broke on an OD to 1st downshift @ 25 mph. Busted the carrier not the gears and it didn't hook either.
Old Dec 20, 2006 | 08:31 AM
koolaid_kid's Avatar
No. I have a Strange 3.42 gear in my series 2 carrier. Weekend car driven hard with multiple trips to the track. T/A cover installed with gear about 25k miles ago, Nittos on stock 16" wheels.
Old Dec 20, 2006 | 09:19 AM
bad2000z's Avatar
Superior 3.73's, T/A girdle, stock axles, 28x9 ET Drags, 1.52 60' times for 2 years with no problems....yet.
Old Dec 20, 2006 | 09:30 AM
Rebelord's Avatar
4.11s stock tosen and no t/a girdle. slicks, 1st run, one wheel wonder now. havent busted open yet, still stuck in japan. but sure its not very pretty.
Ski
Time for a 9inch!!!
Old Dec 20, 2006 | 04:37 PM
Mach1killerls1's Avatar
recently busted the posi in mine after 9 or 10 mid 11sec runs. stock rear w/ 2:73's a 3k stall and about 440 to the tire on the bottle. the rear lasted many low 12 runs up until the point i broke into the 11's. i'm running m/t et streets and plan on going with a tru trac with 3:42's or better.
Old Dec 20, 2006 | 04:42 PM
bad2000z's Avatar
Oh yeah, I have an Eaton Posi too.
Old Dec 21, 2006 | 02:23 AM
revtime's Avatar
My 3.73 10 bolt lasted for years, then I installed a real transmission and busted the pinion gear after 1500 miles.
On street tires and I have yet to hook up the transbrake.
Old Dec 21, 2006 | 02:45 PM
Ouija's Avatar
Diff is doing fine. 3.42 on a series 2 carrier, but not a lot of track time.
Several bottles of spray, built trans, girdle and stud kit.
I always pre-load when racing.
Old Dec 21, 2006 | 08:50 PM
gillbot's Avatar
Stock 3.42 with 3 series carrier and it's holding up fine. I launch off idle.
Old Dec 21, 2006 | 10:39 PM
Kent1's Avatar
I run 4:10's with a 4200 Yank and I have broken gears and differential twice at the track launching the car bwteen 2800 to 3500 RPMs(if front brakes hold) while at the track. Normally I got maybe twenty runs before the rearend went out. With the 4:10's I have now, last year I broke a big piece of the differential at the track, but I cleaned out the inside and put it back together and I have made about 60 passes with no problems-go figure. I do not used a T/A cover.
Old Dec 26, 2006 | 07:47 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
stock 3.42s in a 2 series carrier with a girdle. Sprayed out of the hole ( 1.5x 60ft) and probably had 60-70 passes on it. Never made a sound. Oh yeah it also had ring gear spacer
Old Dec 26, 2006 | 12:11 PM
gator's 99TA's Avatar
a local buddy of mine has a 97z that has gone 1.44 60' on his full weight camaro 396 lt1 with stock 10 bolt with 3.73 gears and no cover.
