How can I make a lockup switch?
Spliceinto that wire with another wire, run the new wire into your passenger compartment, to a momentary switch mounted in the location you want. run the other lead of the momentary switch to a ground.
When you hit the switch it grounds the wire, and will lockup the converter.
I don't remember off the top of my head which wire it is for the '01 models.
Larry
<strong>If you add a manual switch, how would it affect the PCM when it wants to lock up the converter? Or would it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My understanding is the pcm locks up the converter by grounding that wire. By splicing into that wire where you can manually ground it has no i'll effects.
I used this setup for quite some time on my 4l60e with zero problems. I have a t350 now, but I still have that wire rolled and tied up behind the dash in case I ever go back to a 4l60e, and want to use it.
