Install T/A girdle without swaybar relocation?
Old Dec 26, 2006 | 08:51 AM
alamantia's Avatar
Default Install T/A girdle without swaybar relocation?
Has anyone had any success installing their T/A girdle without having to buy relocation sway bar brackets on their stock 10 bolt? I converted my spare 4 channel rear into a 3 channel for my 3 channel car and I am about to do the swap this week. I have a T/A cover for it but it looks like it may interfere with the sway bar. I have heard of buying relocation brackets (i think spoon makes them) to give more clearance between teh cover and the bar but is this for aftermarket rears or do I need them for my stock rear? Has anyone installed this girdle on their stock rear and not needed the relocation kit???
Old Dec 26, 2006 | 10:29 AM
BitViper's Avatar
I did it just Sunday...no problem at all
I did loosen my PHB just to make installation easier....
Old Dec 26, 2006 | 10:36 AM
alamantia's Avatar
cool dude, thanks, does the sway bar look close to the girdle or is there still a good size gap between them? Good size meaning 1/2 of an inch or greater...
Old Dec 26, 2006 | 12:04 PM
Zepher's Avatar
this is what mine looked like (now has a hole in it from bolt that didn't want to be part of my differential anymore and decided to leave), there is plenty of room
Old Dec 26, 2006 | 12:59 PM
alamantia's Avatar
cool man, it looks good with lots of clearance all jacked up, my concern was when the car was sitting on the ground if the sway bar came up any higher, i never thought to look when it was on the lift and now the car is sitting at home in the back of the garage. I dont forsee it being an issue I just wanted to throw a post out there and make 100% sure so you fine people could reassure me all is good.
Thanks guys
Old Dec 26, 2006 | 10:34 PM
SSmokin 01's Avatar
No issues here. I had it on my previous car and now on the wifes. No interference. Here's a shot. Angle's not that great, but you get the idea.
Old Dec 27, 2006 | 04:06 AM
alamantia's Avatar
awesome, you guys are alright
Old Dec 27, 2006 | 07:07 AM
MeentSS02's Avatar
Kleeborp the Moderator™
The only rears that have a problem with that type of cover are the 12-bolts. No sway bar relocation for you!
Old Dec 27, 2006 | 07:30 AM
ICRAZY6's Avatar
Where's the best place to pick one of these covers up cheap???
Old Dec 27, 2006 | 07:43 AM
alamantia's Avatar
Finally, a positive note for the 10-bolt, go 10-bolt!
