1/2" studs with stock 16s
Old Aug 12, 2002 | 07:27 PM
01 NBM DEMON's Avatar
Default 1/2" studs with stock 16s
i am planning on ordering my 12 bolt next week and i want it with the 1/2 studs, i would like to know what i have to do so that the stock 16s would fit since i dont't want to buy 2 sets of welds for the rear, since i would rather run around everyday on the stock wheels
<small>[ August 12, 2002, 07:28 PM: Message edited by: 01 NBM DEMON ]</small>
Old Aug 12, 2002 | 08:54 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: 1/2" studs with stock 16s
Just purchase some new lugnuts. I got mine from Summit. The 16s fit just fine.
Jason
Old Aug 12, 2002 | 09:22 PM
Quick Time's Avatar
16s will fit but you not be able to use you lug nut caps. I know if you have a 98-99 Z28 it has the center cap that its attached via the threaded lug nuts. So if you went 1/2" you wont be able to run the center cap. Go with the metric studs. Just get the longer ones if you want.
