true-trac question?
Old Jan 6, 2007 | 02:54 AM
DVS99TRANS's Avatar
Default true-trac question?
I just blew my zexel/torson and installed a true-trac for a temp fix in the 10 bolt because the car is my everyday driver. It seems to whine alot more than stock and just want to make sure it should be louder, I would figure. And also how street-able is it?
Old Jan 6, 2007 | 07:30 AM
EPP's Avatar
EPP
The Truetrac should not be any louder. The Truetrac is not noticeably any different that the stock unit as far as driveability is concerned, although it is a lot stronger. The 10 bolt cases flex a lot, and this may be the cause of your gear noise, which I haven't really found anything to correct. You can have a quiet 10 bolt, get on it a few times, and have gear noise ever after. Automatics are kinder to the 10 bolt that the stick cars are. Bob
