12-bolt u-joint
Old Jan 6, 2007 | 09:56 AM
mikes98z's Avatar
Default 12-bolt u-joint
Will a stock driveshaft from a 12-bolt car directly fit a 10-bolt or will I have to change the ujoint out that mounts to the rear end yoke?
I am doing an upgrade on my LT-1 car. Thanks!
Old Jan 6, 2007 | 11:48 AM
RA4926's Avatar
the drive shaft will work fine but the rear x-joint may be too big. i would just buy a stock x-jount incase.
Old Jan 6, 2007 | 12:02 PM
TDP's Avatar
TDP
It won't work. The 12-bolt uses a "447" conversion u-joint. You just need a stock one.
Old Jan 6, 2007 | 12:23 PM
jimbo98z's Avatar
What type of car are you getting the driveshaft out of? GM only put 10-bolts in 4th-Gens, so it probably won't be the right length, unless you just mean you're snatching the stock driveshaft out of a 4th gen that has been swapped to a 12-bolt, in which case you should go ahead and put a new stock size U-joint on there anyways.
Old Jan 6, 2007 | 11:19 PM
mikes98z's Avatar
its out of a 99 T/A...had a 12-bolt put in it and the guy stepped up to 3.5" CF shaft. I have a 10-bolt in mine and was wondering if I needed to replace it and what the best u-joint would be.
Thanks!
Mike
