Drill Mod ????????
1) you remove the clutch line from the master cylinder (must remove master cylinder from the car) and the tranny.
2)get a .125" (1/8 th) drill bit and drill from the master cycender side.
3) once the restictor is out, blow the line out with compressed air and run A LOT of clutch fluid through to make sure it is clean (people have scraped their slave because they didn't spend enough time cleaning the line).
4) reinstall and blead the clutch (this is a SLOW and tedious process).
