Need help with T/C lock-up switch
Old Aug 19, 2002 | 04:14 PM
SilverHawk#183's Avatar
Default Need help with T/C lock-up switch
Put the switch in. Spliced into pin 42 Tan/Blk wire and does not work. Should the car die when you push it when the car is in drive. If i ever get to work when do i use it when racing.
Thanks
Wes
Old Aug 19, 2002 | 04:20 PM
Superman's Avatar
Default Re: Need help with T/C lock-up switch
Yes it will die in Drive standing still. You did conect the other side of the switch to ground right?
Old Aug 19, 2002 | 04:31 PM
Yes i have it grounded. I am using a momentary switch. Should this throw a code?
Thanks
Wes
Old Aug 28, 2002 | 06:34 AM
Mike's 01WS6's Avatar
Do you use it in third gear? Also if you flip it on the dyno do you hit it in 3 gear right before you go wot.
Old Aug 28, 2002 | 08:27 AM
Patrick G's Avatar
LS1 Tech Administrator
Please tell me you didn't hit the lock-up switch while you were at a stand still? That's not good. You want to only use it in 2nd, 3rd, and 4th gears once you're up to speed.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
