Visual gear identification
Old Jan 17, 2007 | 05:12 PM
Element's Avatar
Default Visual gear identification
I've got two sets of gears - one set of 4.10s, and one set of 3.42s. Only thing is, they were both in the same box and I don't know which is which
Is there any way to determine the gear ratio by counting the number of teeth on both the ring and pinion?
Old Jan 17, 2007 | 05:23 PM
keliente's Avatar
Yep. Count the # of teeth on the ring gear and divide it by the # of teeth on the pinion.
Old Jan 17, 2007 | 10:09 PM
Element's Avatar
Does a set of 4.10 gears have a specific number of teeth on the pinion or gear?
The ratio I keep getting 41 ring/11 pinion and 41 ring/12 pinion comes out to a 3.73 and a 3.42 gear ratio. The set of what I thought were 4.10s evidently...aren't?
Old Jan 18, 2007 | 07:25 AM
99zman's Avatar
4:10's are 41/10
