ATF in the Differential???
Old Jan 24, 2007 | 06:38 PM
JVs95LS1Z28's Avatar
Default ATF in the Differential???
Sup everybody, I swapped rear ends in my car because I had never taken out axles before and I thought my bearings were bad. So when I took the rear end out of my car and finished swaps, I was curious and opened up the diff. I had taken out. When I opened it, I noticed pink fluid was coming out and it didn't have a smell... I think it was ATF... But my question is can you use ATF in the rear end? Will it protect like gear oil? The reason i ask is because the one i took off didn't have any gear whine, and the one i put in does... so its like trading one problem for another...
If anybody has any feedback on this, i'd appreciate it... Thanks...
Old Jan 24, 2007 | 09:49 PM
alamantia's Avatar
ATF is not GL4 rated, use gear oil
Old Jan 28, 2007 | 10:37 AM
thunderdan74's Avatar
I think you're the new poster boy for 'If it ain't broke, don't try to fix it!' What made you think the bearings were bad? ATF in a rear end is bad news.
