HELP ASAP
Old Aug 24, 2002 | 08:03 PM
01 NBM DEMON's Avatar
Default HELP ASAP
ok here is my problem i just have my tranny built and i put everything in, i did the drill mod on the master, and driving around normal the tranny shifts perfect, but when i hit WOT the around 5000 rpm the car free revs and hits the limiter, the pedal gets stuck up top and takes a lot of force to push it in, when i do push it in it sticks to the floor, and the tranny won't get out of gear, so i pump it a few times and it goes back to normal, i have the McLeod rev lok II clutch and have had 0 problems with it so what could it be????????????
Old Aug 25, 2002 | 08:38 AM
Default Re: HELP ASAP
TTT
Old Aug 25, 2002 | 10:18 AM
TTT ANYBODY OUT THERE
Old Aug 25, 2002 | 10:24 AM
Fireball's Avatar
thats a new one to me <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
But I had a problem with the older Rev-Lok clutch...the hub itself cracked causing the disk to stick in the PP. Not saying thats it but the hard to disengage troubles me...I'd say pull the tranny and check the clutch to be sure <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Aug 25, 2002 | 07:27 PM
MechMan's Avatar
TTT
Old Aug 26, 2002 | 12:13 AM
wrencher's Avatar
wrencher
#1 at 5k + full load it sound like your clutch slips under high loads. T.o.b. shims? I dont know but ya gotta pull the trans to fix it. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> #2 you definetly have a hydralic problem ,not leaking or just seaping anywhere? It almost sounds like disc gets jammed up on input shaft & you force it off with t.o.b. &it looses hydralic pressure in the process. I never heard or seen one like this. I have heard a few mcleod horror stories.
Old Aug 26, 2002 | 07:04 PM
pbperformance's Avatar
you need the mccleod master and the 02 slave ....this should fix the problem
