Moser 9 inch instalation help
What you need to do is assemble the axles in the following order:
Say the hub is on the ground, you would put the reluctor ring on(if you have a 4 channel setup), then the brake backing plates(make sure the face the correct way), then you press the bearing on, then press the press ring on which helps keep the bearing on. What actually keep your axle in the housing is those brake backing plates, there are studs on the housing and nuts on the brake backing plates holding it against the housing and keeping the bearing in.
The backing plates say LH and RH, you may have them on the wrong axles. Also make sure you have the axles in the correct sides, and make sure the bearing is all the way inside the housing. before you try putting the nuts on to hold the backing plates to the housing.
Also, did you switch your u-joint yet? I'm having some snapring issues.
https://ls1tech.com/forums/gears-axles/648943-9-inch-install-tips-tricks-vendor-feedback.html
