rear end???
Old Feb 10, 2007 | 08:44 AM
bigdcustoms's Avatar
Default rear end???
when ever I do a burnout at the track, my limited slip posi traction rear end starts to burn out and then all of a sudden one side just stops spinning while the other just keeps spinning...is this how limited slip is supposed to work...
Old Feb 10, 2007 | 11:15 AM
purdueranger's Avatar
Sounds like your posi unit is worn out. Mine spins both tires turning the whole burnout.
btw how long is your burnout?
Old Feb 10, 2007 | 12:07 PM
Proud2bSS's Avatar
Just a few questions:
What type of posi?
How old since the install?
Last time fluids were changed?
Correct limited slip friction additive?
Old Feb 10, 2007 | 02:07 PM
well I bought the car like 4 years ago and then I started to rebuild... I havent had any reason to change it... but that is the first thing im going to try is changing the fluid...
Old Feb 10, 2007 | 06:04 PM
my burn outs are as long as I want them cause I have line lock...usually long enough until the smoke pretty good...
