Got a roational clunk in the rear?
Old Feb 11, 2007 | 01:24 PM
blk97z28's Avatar
Default Got a roational clunk in the rear?
Ok i have a 97 camaro z28. i have tried the searches and i need still to explain my problem. I have a clunk sound like from the backseats and over to my left which would be my back passanger side area. I can drive it and it kind of makes a growl or grinding howl. If i appile the brakes it does not make a noise? I thought maybe the alxed bearing on the passanger side but i dno't know. I did ingition related stuff and my car sat for about 2 months ni my garage. I added spacers about 1 week before it was done. But once i took my car for it's first test drive it made that howling grinding clunk noise?? I look at my wheels to see if maybe they were rubing and not a single mark on the inside fender, so what gives? I can put my car in netural and push it back and forth in my storage garage and it does not make any clunk, i use to have a sweak kind of in the same area but could that SWEAK have gotten worse to this howling grinding noise? Any info would be greatly aprecciated thanks. Devin
Old Feb 11, 2007 | 02:08 PM
ssrevenge's Avatar
i just went threw this last night..i took of the differential cover and found some missing teeth on my pinion...maybe a start..sounds real similar
Old Feb 11, 2007 | 02:15 PM
blk97z28's Avatar
alright hey thanks, so are u gonig to get new gears when you get your new pinion? How long did it take u? should i jsut upgrade to 3:73:1 gear ratio?
