Trans leaking at U-joint?
Old Sep 2, 2002 | 12:28 AM
Mutant's Avatar
Default Trans leaking at U-joint?
i didn't know any other way to post this, my trans is leaking some fulid. the end of the tailshaft has a seal that the shaft goes up into, the seal is not leaking at all, but it seems the fluid is coming thru inside of the shaft and coming out by the ujoint. is that possible? is there a seal that keeps the fluid from coming out of the middle of the shaft (just the part that goes into the trans)? it leaks while the truck is standing still and driving, if that matters. it's a pain because it is spalshing all over the bottom of the cab. there is not fluid around the seal, just coming out of the ujoints. i thought it might just be grease from when i got it lengthened, but it's not it's definitely trans fluid and not grease
thanks,
allen
<small>[ September 01, 2002, 12:30 PM: Message edited by: Mutant ]</small>
