9" from junk yard
Old Feb 15, 2007 | 04:01 PM
6-Speed Terror's Avatar
Default 9" from junk yard
anyone ever build a 9inch from scratch i wonder if it is possible. sux being on a budget
Old Feb 15, 2007 | 04:15 PM
PlatnumStatuz's Avatar
Wuts ur budget? Probably better off saving for a used or new one. Are you broken rit now?
Old Feb 15, 2007 | 04:21 PM
98TADRIVER's Avatar
its definately possible. there will be some cutting/welding needed to be done. you would need a torque arm mount somehow welded onto your rear so you could use it. you'd have to take measurements, width of housing, axle lengths if u cant cut the stock axles in that rear down to your size or dont wanna use em- (moser has a good diagram for measuring them up on their site), then youll need to find out what housing ends are on that rear (once again, diagram on moser's site) might need a new driveshaft too. im sure a few others will chime in. i was thinking of doing this myself at one time
Old Feb 15, 2007 | 04:22 PM
i have about 1000 i could spare soon, i would prolly go with a spool too.
Old Feb 15, 2007 | 04:34 PM
98TADRIVER's Avatar
spool is a no-no if its a DD, unless you dont mind your car hopping around turns lol
Old Feb 15, 2007 | 04:38 PM
yeah it is dd but its about 6 miles total and like 5.5 of it is highway rest of the time im in the wifes neon
Old Feb 16, 2007 | 02:16 PM
Z'mnypit's Avatar
https://ls1tech.com/forums/gears-axles/657534-9in-questions.html
