9" to ls1 u-joint part#
Old Feb 17, 2007 | 04:33 PM
Ego Killer's Avatar
Default 9" to ls1 u-joint part#
I just bought a used 9" for my 99 TA anybody know the part# for the U-joint I was told the 9" has a 1310 yoke..
Thanks in advance..
Old Feb 17, 2007 | 09:21 PM
chupr0kabra's Avatar
From EPP's web site
You will need the following:
- 1350 Conversion U-Joint (Napa Part # 240-0447) pressed onto driveshaft.
- Axle Bearings Pressed on (Any local auto shop can do this usually): They do not come pressed on because you need to swap the brake backing plates from the stock unit to the new unit and then press the bearings on (This swap is a few minute swap).
- Generic 3" muffler clamps to relocate sway bar.
That's assuming it's a Moser. Not sure about Strange.
-Mike
Old Feb 17, 2007 | 09:25 PM
Ego Killer's Avatar
Thanks, Ill give that a try
