12 bolt problem
Old Feb 19, 2007 | 04:17 PM
stdjsw311's Avatar
Question 12 bolt problem
ok i took a 4 channel rearend out of my 2000 z28 m6. i am putting a 12 bolt strange in it. ok i am trying to put the backing plates on the 12 bolt from my 10 bolt but they dont fit around the axle housing. the bolts holes do not match up either. what do i do??? i would like to have an e-break. i dont care about the abs or the TC. i was hoping it was a easy direct bolt in but u know as well as i do that never happens!!!
Old Feb 19, 2007 | 05:27 PM
stdjsw311's Avatar
should i just machine the backing plates out or what???
Old Feb 20, 2007 | 09:15 AM
stdjsw311's Avatar
come on guys does anyone have an idea????
Old Feb 20, 2007 | 05:08 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Strange does not use a flush mount housing ends so you might have to pocket your backing plates. As for the bolt pattern they should be the same as your stock backing plates. It is a 12 bolt drum pattern that GM some how came back to reuse.
