Paging Fireball
Old Sep 6, 2002 | 10:04 AM
CHRISPY's Avatar
Default Paging Fireball
What clutch setup are you running now?
I need to know everything you have <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
is it a revlok 2 setup with macleod adj master?
what disc are you running? How is it for daily driving?
Are you running stock or macleod flywheel?
Cheers,
Chris
Old Sep 6, 2002 | 01:50 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Paging Fireball
Chris,
I'm running the same setup Brian is. It is the newer version of the Mcleod Rev-Lok II. It has a stiffer pressure plate and a slightly smaller diameter disk. Driveability is better than the original version and it holds even better.
Coach 02 Z28 has this setup as well and has over 150 passes on it cutting 1.50 60'.
I have a complete Rev-lok sedup for sale, with Mcleod adjustable m/c and GM "145" slave in the classifieds:
https://ls1tech.com/ubb/ultimatebb.p...c;f=7;t=005970
Jason
