Any gains??
Old Feb 28, 2007 | 04:54 PM
98z28bitcha's Avatar
Default Any gains??
I am hopefully goin from 2.73's to 3.73's with stock stall, will it be worth it?
Old Feb 28, 2007 | 04:55 PM
bad6as's Avatar
you bet
Old Feb 28, 2007 | 06:05 PM
5_02ls1's Avatar
i done this swap and it made me fall in love with the ls1 all over again.
Old Feb 28, 2007 | 08:03 PM
Thanks guys i am goin to buy new gears next weekend. What is the best gears out there?
Old Feb 28, 2007 | 09:11 PM
marthastewart's Avatar
Cant say what to get but I will tell you what NOT to get. The Motive with the spacer sucks. The spacer makes it almost imposable to align. What ever you choose, make sure its the thick gear.
Old Mar 1, 2007 | 05:53 AM
2001z's Avatar
You need to find a good builder!! My brother just did that exact swap and it is quiet the only noise it makes is a little noise on heavy breaking and even motive says if you want it completley quiet you need to replace the carrier! Just my .02$ And yes going from a 2.73 to a 3.73 is going to be a good diffrence especially on lower speeds! Your spedo will be off by about 20-25 at 70
Old Mar 1, 2007 | 06:27 AM
Formulated's Avatar
You bring up something I was wondering about. Last summer when I was buying my gears, everyone was saying to stay away from the thick gears because they were all noisey. So I got some OEM gears and a 3 series differential. Now a lot of people are going with the thick gears, and everything seems OK. I wonder why the change in enthusiasm over thick gears?
Old Mar 1, 2007 | 06:51 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Its going to be night and day for you.
 Michael S. Palmer
Old Mar 1, 2007 | 09:24 AM
well the main noise causer is improper install. Mine onthe other hand was that ring. It was installed and made a loud grinding/whine. Took it back out and the spacer ring was not true. It was .8 thicker on one side than the other. The company backed it up and sent me another kit. The new one was only .2 out. not great but a lot better. I said screw it and will be running this till I get a 9".
Old Mar 1, 2007 | 06:24 PM
I dont get it which is better thick or OEM? I was goin to do myself but not really that skill with spacers.
