12 Bolt Axle Removal Question
Old Mar 3, 2007 | 08:22 PM
2000LS1TA's Avatar
Default 12 Bolt Axle Removal Question
Hi, I bought a used Moser 12 bolt, and I need to remove the axles so i can put the reluctor wheels on them since my car is a 4 channel. This rear end doesn't have C-Clips, how do I remove these axles. Thanks, Ryan
Old Mar 3, 2007 | 08:27 PM
SKI's Avatar
SKI
Remove the backing plates .There's 4 bolts and out they come.
Old Mar 3, 2007 | 08:46 PM
2000LS1TA's Avatar
I took them 4 bolts out already, then i pulled on the axle, and it didn't wanna budge. Should I try and tap them with a hammer? Thanks, Ryan
Old Mar 3, 2007 | 08:51 PM
RA4926's Avatar
tap it with a rubber mallet, mine takes a little coaxing to remove too. the bearings are in tight thats why its not sliding right out.
Old Mar 3, 2007 | 09:15 PM
2000LS1TA's Avatar
Thank You Very Much Guys, I'll Give It A Shot In The Morning
Old Mar 4, 2007 | 11:08 AM
2000LS1TA's Avatar
Alright, just got back in from the garage. I took the 4 nuts off from the studs behind the axle hub. The Axle Still doesn't wanna move, any more suggestions??? Thanks, Ryan
Old Mar 4, 2007 | 12:07 PM
EPP's Avatar
EPP
A lot of tapping may be required.
Are the axles machined for 4 channel? This is an option, they don't machine them unless a customer orders them for TCS. If not, then I'd just install the rear and not hook up the ABS/TCS. Bob
Old Mar 4, 2007 | 12:12 PM
2000LS1TA's Avatar
The axles look like they are machined. If they aren't, It's not a big deal because my dad's best friend is a machinist. Thanks Again Bob
Old Mar 4, 2007 | 12:24 PM
EPP's Avatar
EPP
Not a problem. Bob
Old Mar 4, 2007 | 01:36 PM
2000LS1TA's Avatar
Thanks for all the help. Took some coaxing, but they're out!!! Thanks guys!
