Rearend Welding?
Old Mar 6, 2007 | 11:31 AM
Topless TA's Avatar
Default Rearend Welding?
I have a 10 bolt that was completely rebuilt w 4.10 Gm gears,
cleaned internally and externally looks like a new rear.
That I am thinking of swapping in my car.
I understand that the 12bolt and 9inch are superior rears
but I have this rear and had heard that welding the housing
along with a TA cover
would help to make it stronger.
I tried searching and couldnt find what I was looking for.
Additionally I am looking at switching to a 18" rim
with a taller tire at the same time so my "net" ratio will be closer to a 3.90
thanks in advace. also if you know what $$$$$ I am looking at
for either that would be great as well
-John
Old Mar 6, 2007 | 11:46 AM
Lazlo's Avatar
I think the weak point in the 10-bolt is the size of the pinion, especially with 4.10s. You could weld some gussets on the housing but you run the risk of warping it, and I don't think it would help all that much.
Old Mar 6, 2007 | 11:51 AM
patriotformula's Avatar
I dont think welding the housing is going to help you much... And there is quite a bit of opinions floating around that the TA cover doesn't do much. Do a search there are some very compelling arguments to this. Anyways with an 18 inch wheel I dont think you'll have enough traction to break the rearend, unless you constantly beat the hell outta the car.
Old Mar 6, 2007 | 11:54 AM
keliente's Avatar
Sprinkle some fairy dust on the 10 bolt while you are at it
I personally would not put a dime into the 10 bolt especially behind a manual car. If it's an auto, leave it alone it has a better chance of surviving than an M6 car. If it's going to break it will break - be it the diff, pinion, ring, axle, etc.
Old Mar 6, 2007 | 12:03 PM
alamantia's Avatar
I sprinkled fairy dust on my first axle and it still broke so i doubt that will work. I believe the housing itself is strong enough, the ring gear is so small at 7.5, i think most of the problems face occur with the internal componunts breaking under stress opposed to the housing failing.
Old Mar 6, 2007 | 12:33 PM
Topless TA's Avatar
IF i had any fairy dust I would not sprinkle it anywhere that would make my car Ghey
It is a M6 and figure the rear is worth about $100 more than the one with
3.42's that are in the car now so i was going to swap and sell the old one.
just wanted to wake it up a little on the occasion
I get a rustang or ricer that wont leave me alone.
Seriously though thanks for the input
I have $600 tied up in the rear and dont go to the track
never beat on my car although I do drive aggressively from time to time
