Which gasket for gear install?
Old Mar 6, 2007 | 08:27 PM
PunkNPonys's Avatar
Default Which gasket for gear install?
I am doing a gear install this weekend and i went to AutoZone to get the gasket and they said they didnt have a part number for the 2000 and up camaro. So i then asked for a 99 and they had one. Well my question is i have heard of guys just using RTV for the gasket but i went ahead and bought both. Which one do yall recommend i use the RTV or the 99 Felpro gasket? Or can i use both? Any help would be appreciated.
Old Mar 6, 2007 | 11:32 PM
00BlueTA's Avatar
I used RTV and have no leeks, just make sure the surface is clean. You and use both gasket and RTV if you want but I would return the gasket and get your money back.
Old Mar 7, 2007 | 10:10 AM
PunkNPonys's Avatar
Ok thanks. The guy at auto zone told me that if i use the RTV with the gasket the gasket will probably slip out and evetually tear. He said usually guys use adheasive with the gaskets. Is this true?
Old Mar 7, 2007 | 10:26 AM
00BlueTA's Avatar
I have heard of people useing some adheasive but I dont know becasue I didnt use a gasket. Just make sure the surfaces are very clean and use a thick beed of RTV, also make sure you get RTV around the bolt holes.
