moser 9 inch problem
Old Mar 7, 2007 | 07:19 PM
joser the poser's Avatar
Default moser 9 inch problem
hey guys just got my moser 9 inch from epp and everthing is great except it makes a gringing noise when i turn left, kind of like if something is binding, happend only after the install, i was thinking it could be maybe i just need to some gm slip additive but its the true trac which dosnt require the addivtive because its not spider gears like the eaton posi correct? any ideas? drives better now and no more loose torque arm bolts!
Old Mar 7, 2007 | 08:08 PM
1BadAzzWS6's Avatar
sounds like it's not set up correctly...stop driving it and have it checked out asap.
Old Mar 7, 2007 | 09:16 PM
EPP's Avatar
EPP
I'd check your brake backing plates, and make sure all the bolts are tight. It could be a loose bolt against a brake. Also check for clearance between the body and the torque arm, etc. Bob
Old Mar 8, 2007 | 11:05 PM
WE TODD DID's Avatar
What carrier is installed?
Old Mar 10, 2007 | 10:45 AM
well drove it today and did not make any noise, so its all good,
Old Mar 10, 2007 | 11:27 AM
EPP's Avatar
EPP
Thumbs up
Awsome! Good to hear. Bob
