gear at the line
I've only ran the 1/8 so far with my new rear and I am right at 6000rpms at the finish line in third gear. Will I be able to make it in the 1/4 without having to hit fifth?
With a 6500 rpm redline and 26x11.5x16 ET Streets you can do 125 in 4th gear or 121 @ 6300.
If you go with a 28" ET Drag like we talked about the other day, you'll have plenty of room. You need to scrap those ET Streets and get some MANLY tires under the back-end for some wheels-up launches. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> With a 28" tire and 4.10's, you'll be just fine. Jason 98 TA, among others, ran 4.30's with 28" ET Drags and crossed the line at 126 MPH in 4th gear. Your shift points will be a determining factor as well, as Joel said, as to where you cross the finish line RPM-wise.
Get a set of fat tires under the back with some nice sidewall, and you'll thank me after you launch on them for the first time. <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Trevor - LGM
