Rear end not a posi!! Help!
No! There is now way you should invest that kind of money in a 7.5 rearend. You can either pick up a used 7.5 in good working condition for a couple hundred bucks, or go all out and order a 12 bolt or 9 inch from a sponsor of this site. Even if Dad is picking up the tab, don't have him waste his money. He will be pissed when the new rebuilt 7.5 snaps.
Yes! Defintely get you rearend issues worked out before investing in other mods. If I read correctly, you are getting the one wheel peel now. You will not realize any performance improvement unless you get the power to the ground.
