driveshaft reinstall question
Old Mar 12, 2007 | 10:32 PM
brad8266's Avatar
Default driveshaft reinstall question
I put marks on it when i took it off so that i would put it on the same way after i was done but the marks mysteriously dissapeared. I just put the driveshaft back in anyway, so if it is in the oppositie way will it make a difference in balancing or will it be fine?
Old Mar 12, 2007 | 11:16 PM
bigdsz's Avatar
Obviously you have a 50% chance of getting it back where it was. Should you have vibration, which is unlikely, just rotate it 180*. From the factory they are not balanced with any other part of the drivetrain.
Old Mar 13, 2007 | 01:49 PM
brad8266's Avatar
Thanks, i didnt think they came balanced.
Old Mar 14, 2007 | 01:27 AM
02NBMWS6's Avatar
ive had mine in and out so many times, and ive never marked it. it should be good man
Old Mar 16, 2007 | 12:43 AM
00BlueTA's Avatar
When they balance the drive shaft they do it form the yoke to the u-joint. It doesnt matter if you just took the drive shaft out and put it back in, that changes nothing.
