Pinion-Nut Torque with Solid Spacer?
Old Mar 16, 2007 | 11:05 PM
Gary Z's Avatar
Default Pinion-Nut Torque with Solid Spacer?
What is the recommended torque for the pinion nut when using a solid spacer in a 12-bolt?
Old Mar 21, 2007 | 01:29 PM
Gary Z's Avatar
The nice lady who answers the phone at Ratech says 125 ft-lbs.
Old Mar 21, 2007 | 02:05 PM
oange ss's Avatar
should be 35 in-lbs for a new bearing/ 15 for a used bearing..that is running torque
Old Mar 21, 2007 | 03:57 PM
mzoomora's Avatar
14 Second Truck Club
That is right, but you still should shim it for the rotational preload. I usually go 25 in/lbs for new bearings.
Old Mar 22, 2007 | 08:28 AM
turbotko's Avatar
yeah, 25-30 inch pounds of preload with new bearings. The ratech pinion spacer I got said 125 ft/lbs for torque on the nut. Just make sure you have it shimmed right before you torque her down. Don't want to damage the bearings by torqueing it down with too few shims!
