new 9" whine
Old Mar 16, 2007 | 11:53 PM
The95Firehawk#250man's Avatar
Default new 9" whine
i got my 9" made from moser and a driveshaft installed at a machine shop. i have put 80 miles on it so far and 6+ heat cycles, and it whines when i let off the gas and its pretty loud. i am hoping it will get quieter as it breaks in?? it has been hard but i haven't gased it or shifted it hard yet.
Old Mar 17, 2007 | 04:55 AM
EPP's Avatar
EPP
Do you have an adjustable torque arm? If you do, check the pinion angle. Although rare, I have seen it cause noise like you described. Also check for rear end interference with the body when the weight is on the tires. Bob
Old Mar 17, 2007 | 05:04 AM
JEB99TA's Avatar
My 12-bolt started sounding like a jetliner slowing to land on deceleration, just after I had the pinion seal replaced ... now, it's going in the shop because there's a grinding noise coming from it when I turn the wheels 10-15 degrees when I'm stopping. I'd have the have the setup re-checked wherever you got it installed. A lot more experienced people than me, but, just my opinion.
Old Mar 17, 2007 | 07:10 PM
i thank you JEB99 for your response. hey bob just have a non adj. torque arm. so you recommend 500 miles before putting any shock on the rearend?
