Pinion Depth
Benjamin
torque the pinion nut till you get right around 20 inch pounds of rolling torque
install your carrier/ring gear,
set backlash at .008"-.010"
mark your gears and take a pattern in both directions
if it is good, take it all back apart again and install your crush sleeve and pinion seal
if it isnt good add or take away pinion shims to get a good pattern, always re-set backlash after a pinion shim change
I just put some motive 3.73's in mine with a detroit trutrac diff. I took me 14 hours to get it where I was satisfied......but it doesn't whine one bit. I probably changed pinion depth 10 times.
Do yourself a favor, get the ratech solid pinion spacer. It took me a little longer to get the preload setup right due the shims but it will help your poor 10 bolt maybe maybe last for a while behind that 6 speed.
Or maybe not
